2 in spacer lift
thoughts on using a 2 inch spacer lift with stock suspension? just looking for a budget way to get some more clearance. this is the kit I was looking at, any thoughts would be appreciated.
Black Diamond 700600 - Black Diamond 2" Spacer Lift for 07-13 Jeep® Wrangler & Wrangler Unlimited JK - Quadratec
I have a 2.5" teraflex budget boost with shock extensions and have no complaints. They run about $350 I believe. A little more expensive but a much more complete kit. The TF comes with bumpstops, brakeline extensions, shock extensions and rear trackbar bracket.
What size tires are you planning on running? I would say the teraflex kit would be a great option , but only if you are going to run 33s or 35s but it would look a little goofy on stock size tires
