can I mount a 33" on the stock spare with some accessories?
Old Jun 9, 2013 | 02:17 AM
Kojack's Avatar
Default can I mount a 33" on the stock spare with some accessories?
I'm adding a 33" tire on my spare as well as a high lift, a vector off road rack with 2 rotopax cans. Will my tailgate be ok? I'm planning on the teraflex hinge later. But want the rack this summer for extra gas and backup lighting.
Old Jun 9, 2013 | 03:27 AM
Tripletsi's Avatar
It depends on the overall weight of the entire setup. Chrysler suggests (with the bike rack added to the spare) the tailgate to hold a max payload of 75lbs, and only for short periods of time. It sounds like you'll be above that weight limit for sure. I suggest the TF HD Hinge as your first purchase, it's easier to prevent damage than to pay to have it repaired.
Old Jun 9, 2013 | 04:00 AM
MFX's Avatar
MFX
I had a 33 duratrac mounted on a 18" rockstar and that alone wore out my hinge. I now have about 1/8" of play on both the upper and lower hinge.
Old Jun 9, 2013 | 04:14 AM
OH9JK's Avatar
JK-Forum Ambassador
FYI a 48" Hi-Lift weighs around 30 lbs and gas weighs in around 6 lbs at per gallon....plus the weight of the container.
