not adjustable control arms for a 4 inch lift
The problem is that wit 2,5" to 3" of lift, you can get away with only the lower front control arms on the upper rear control arms. Mowing up to 4" of lift, you might need all 8 control arms, to gat every thing in alignment. A full set of 8 control arms will run you about $1200. Look on Teraflex, Rock Krawler and Metalcloak's website to give you an idea. You might look into RC arms too, but from what I have read on here, they are not to good.
Hope this help you out.
I can't speak for quality but the RC are by far the cheapest I found and then Rustys are next but I couldn't afford either at the time and will be having to upgrade later. Just hope I don't hurt too much before I can get some myself. I have read on here that RC really stands behind the parts very good.
Edit* - I bought these after trying to do without the adjustable arms on a Rancho 4" sport kit (sounds similar to your situtation_. The brackets didn't give me enough caster with the stock arms so I ditched the brackets and moved to these (which was always the plan anyway once I had the cash). FYI though, once you upgrade the arms, the very next thing I did was tear my driveshaft boot with the extra articulation, so if you're running stock skids either notch it or replace with something with some more clearance.
