mopar dana 44 front "rubicon axle swap
I have a 07 4dr X with anti spin rear axle and 4:10 gears with ESP. I have a front dana 44 "rubicon" axle ordered. My question is will this bolt right up to the driveshaft or is the pinion longer? u-joint different? I am installing a 4" lift at the same time. Thanks in advance!
The axle should be a direct bolt in, but you will need some additonal items to control the locker in your new axle.
Blue, has a good point in that you might need to replace your driveshaft due to the 4" lift.
I would suggest you read through this thread for more info, others are performing this mod and should be able to help you out.
https://www.jk-forum.com/forums/modified-jk-tech-2/questions-about-rubicon-axles-25049/
Yes, it will bolt right up without any problems. As far as drive shafts go, if you have a 6-speed, you will be just fine with your factory shaft - I am running this setup now. If you have an automatic, you will need to at least trim your automatic tranny skid to prevent the driveshaft boot from contacting it at a droop. But, you should otherwise still be fine with the factory shaft.
now is that only on a 4dr that u dont have to swap the ds or can u run a 4'' lift with 35's with 6spd and not have to change shafts. I am really wanting more lift but dont want to change my ds, i only do moderate wheeling and dont want to spend the money on ds yet. please let me know.
I would like to put the oem dash switch in along with the front rubicon axle. 4wd has the switch part # 04602508ae, this switch includes the sway bar switch. I would like to know if anyone has a rubicon with esp and not the electronic sway bar. I need the vin # so my parts guy can look up the sales code for that switch. or if anyone here works at a jeep dealer and can get me that part#. If you don't want to post your vin here, you can call me toll free 18775409908
