Upgraded Gears/Tires? What are your RPMs?
Old Feb 5, 2008 | 07:37 PM
wayland1985's Avatar
Default Upgraded Gears/Tires? What are your RPMs?
Out of curiosity, for those of you with upgraded gears and tires, what RPM's are you seeing?
Please post your:
Transmission type
Tire size (exact size and brand would be great)
Gear Ratio
For manuals: What is the RPM range in 5th gear at 65mph?
Old Feb 5, 2008 | 07:44 PM
Mowabb's Avatar
roughly 2300 @ 70 mph
Auto trans
37x12.50 17" BFG KM2
5:13
Old Feb 5, 2008 | 08:51 PM
KenB1010's Avatar
3000 RPM @70mph
6 speed
35x12.5 17" BFG KM2
5:13
Old Feb 6, 2008 | 07:23 AM
TEEJ's Avatar
Talking
If you want an easy range...just look at the percentage differences from what you have....if you get gears that are 10% deeper, your rpms will be 10% HIGHER.
If you get tires that are 10% larger in diameter, your rpms will DROP 10%, etc. (The tire makers typically list the rpms per mile for their tires, by size...you can compare that # to your stock tire's rpm/mile, and get a percentage difference that way too.)
That's why if trying to stay with a stock feel, if you get tires that are 10% larger, you'd swap in gears that are 10% deeper to compensate....if you want a boost in ooomph, you'd go a bit deeper than that in gearing to make up for the weight you'll probably add later, etc.
