Will 2012 rubi tcase fit behind an 07?
I know trans are dif between the yrs. wondering if the output shafts are the same and if its a clean swap to put a 2012 rubi case in 07 x?
apparently the 12-13 auto cases are different then all the others. If you have a manual should be the same.
