Question on evo tire carrier, help me please
Old Jul 12, 2013 | 01:22 AM
RedFox's Avatar
So I got my evo carrier, and my questions are
1- to install the brackets for the carrier, do I need to install nutserts in the hole locations?
2- do I install a nursert where the hole to the right of the gascap hole is located? I know this is an attachment point for the upper driver side bracket, I just don't know if I install a nursert there??
3- what are the long bolts and shouldered bolts for? they are included in the hardware for the builder corners.
4- what size drill but do I use for all the holes?
I know some guys on here have installed the carrier, and I would really appreciate the help!
Old Jul 12, 2013 | 06:16 AM
Biggy's Avatar
I know some guys on here have installed the carrier, and I w ould really appreciate the help!
1 nutserts are not used to install the brackets they are through bolted with the supplied hardware.
2 You do not use a nutsert here its for the bracket and gets a through bolt.
3 Not sure I didnt have those with mine.
4 I cant remember but should tell you what size in the directions.
