jacking up using hi-lift
It should be solid enough.
Hi-Lifts aren't very useful and they are dangerous. I wish i didn't buy one. A scissor jack under the axle is probably best. A bottle jack modified with a an angle iron in a "V" on the top may be more useful.
I jacked up my Jeep by the slider with a Hi-Lift to test out my welds. That was the only use. It can also be used as a poor-mans winch.
And it's a good idea to get familiar with it as much a possible. I use Hi-Lift (on bumper) to put the jeep on jack stands when I rotate my tires. PS: I keep my on my Jeep, so it gets rusty/stuck if I don't....
You'd be better off with a bottle jack under the axle if you're goal is to get on jack stands. You'll have to lift extra to compensate for suspension.
I bought my hi lift pretty much to pull me along if the winch breaks or if I get stuck and have to pull out backward (no winch in the back). Actually lifting the jeep to change a tire is the bottom of my list unless it's the only way...
They work good to lift a tire up to stack something underneath the tire for traction. For changing a tire you for sure would want to make sure the jeep was stable and would not move. either way you need a strap wrapped around to keep the suspension from sagging otherwise you will have to really lift the vehicle to get a tire off the ground.
