2012 Jk breather hoses DO NOT extend above wheel well.
Old Jul 16, 2013 | 05:22 PM
IslandJeeper's Avatar
Default 2012 Jk breather hoses DO NOT extend above wheel well.
So i just took a look under my 2012 4dr and as it turns out the breather lines for the axles are not extended. the rear axle ends at the top of the right rear wheel well, and the front ends at the top of the left front wheel well next to the shock. also the transfer case ends above the engine but not into the engine air intake like the auto tranny one does. anyone extend all of these hoses into the air box? Im going to attempt to extend them into the air box so when i get a snorkel i can actually go swimming in my rig. stay posted im going to start this tomorrow and make a write up
Old Jul 16, 2013 | 05:31 PM
08rubie's Avatar
Oh good can't wait!!
Old Jul 16, 2013 | 06:13 PM
Jonathan_JK's Avatar
Check out river raider. Bobs extender kit will take care of those problems.
Old Jul 16, 2013 | 06:27 PM
that looks like a good kit! I would like to see if i can pull it off on a tight budget. stay posted!
Old Jul 16, 2013 | 06:35 PM
I'm sure you could piece a kit together for less than $64 bucks. But I like not having to search for the right fittings and cutting the hoses to the right lengths.
Old Jul 16, 2013 | 07:39 PM
^^truth, im just surprised that they extended the transfer case hose and none others. that being said i had taken my jeep swimming ALOT and when i had the stealership change the diff fluid they said it was clean guess im lucky
