Body Bolts
Does anyone know where I can get some replacements maybe 1/4" longer? Size even? Got new rocksliders "designed" to be installed with the stock but they are too short and just barely grab - two stripped out when I was torquing them at just 40lbs - saw the tips were just barely grabbing.
Thanks for any advice.
Thanks Planman - I called one of the companies earlier and asked for just the bolts but they advised that theirs (and most others) require you to rep,ace the nuts too and I just want to try using the stock nuts rather than tearing the entire body apart to get to them.
I called two of my local hardware stores looking for Grade 8 and they said they could order so I was hoping someone knew the proper size that I could "plus up".
I've spent hours online at OEM part sites and while I found the bolts, they didn't say the size that they are.
Frustrating. 30 min install, 6 days to get it right!
I just went through the same thing on my sliders, except it was a different bolt that didn't even come on a manual JK.
