Tire balancing with Equal?
Old Feb 7, 2008 | 08:37 AM
monte's Avatar
Default Tire balancing with Equal?
Has anyone had their tires balanced with a product called Equal? The local shop suggested I go with this option. Any suggestions on the best balancing option for 35x12.50.17's?
Old Feb 7, 2008 | 09:21 AM
RabidCow's Avatar
I don't think I would try that. What if a little bit of moisture got mixed with the equal? I would guess it would migrate to some spot and then stick, possibly in the "wrong" spot, making the imbalance worse, rather than better. I really don't know, but it would seem to be a bit of a gamble.....
Old Feb 7, 2008 | 09:25 AM
fish's Avatar
From: Apple Valley, California Good ole Mojave Desert.
Wo yeah i hope it's not the equal i'm thinking of. maybe some tire product,gotta look.
Old Feb 7, 2008 | 09:39 AM
RabidCow's Avatar
Lol, I should have googled before speaking. Equal is a product by IMI for balancing tires. I will assume that it won't clump up in the wrong spots, but I haven't used anything like that so I will await the opinions of those more experienced .
Old Feb 7, 2008 | 09:42 AM
j&k'sjk's Avatar
We use a sand like product in are truck tires for balancing but were talking about Dump trucks/ Fire engines, etc. Not sure how good it will work in a smaller tire.
google dyna beads
Old Feb 7, 2008 | 09:57 AM
2K1TJ's Avatar
I wouldn't think you'd need them with your Toyo's. Internal balancing stuff is usually reserved for more aggressive tires, such as Swampers.
I was thinking about using this stuff or some beads in my 37's, but I just had thme balanced w/ regular lead weights, and they ride slick as glass.
Old Feb 7, 2008 | 10:12 AM
monte's Avatar
I just talked to a guy in a 4x4 shop and he said that thye use Dynabeads, which is a similar product to Equal, but he didn't think I'd need it for Toyo's. He suggested stick-on lead weights on the inside of the rim. Does anyone use Dynabeads? Has anyone had issues with balancing Toyo Open Coutry M/T's?
Old Feb 7, 2008 | 10:53 AM
Goose's Avatar
Here is a thread about using wheel balancing agents like equal. Post #6 has a list of different experiences that yellowjeeper85 went through.
https://www.jk-forum.com/forums/show...=wheel+balance
Old Feb 7, 2008 | 10:58 AM
monte's Avatar
Thanks for the link, Utahgoose!
Old Feb 7, 2008 | 11:10 AM
HappyCurmudgeon's Avatar
Eternal ***erator
Hell no! that crap causes cancer
my tires are sick enough.
