35s
Old Jul 26, 2013 | 07:31 AM
Jk-Jared's Avatar
Default 35s
Do I need to re gear my 2009 JkU so i can stuff 35s under it
Old Jul 26, 2013 | 07:39 AM
SabrToothSqrl's Avatar
Default no
re gearing affects drive ratio, not fitting the tires.
you may want a 2-3" lift however to fit 35s.
Old Jul 26, 2013 | 07:44 AM
kh202's Avatar
No you don't HAVE to. What's your gear ratio now?
Old Jul 26, 2013 | 07:47 AM
jk.bushwacker's Avatar
NEED? No but you might want to... what gearing do you have now? what type of tread will you run? MT/AT etc. easiest way to find out is mount the tires and see how it "feels" to you. then you can regear if necessary. im running 35s and haven't regeared yet but I do plan on doing it sometime but its not that big of a deal for me. its prob more of a personal preference thing and depends a lot on your driving habits.
Old Jul 26, 2013 | 08:58 AM
Jk-Jared's Avatar
Right now im running stock 3.21 ratio
Old Jul 26, 2013 | 08:59 AM
Jk-Jared's Avatar
I will be running the nitto trail grapplers and since in 16 i will be driving to school more than offroad
Old Jul 26, 2013 | 09:02 AM
Jk-Jared's Avatar
But what about for gas Milage i don't want that sucked down or a loss of power im 16 and gas Milage is everything since i will be on the rode most of the time but i plan on a lot of offroading too
Old Jul 26, 2013 | 09:05 AM
JK Inspired's Avatar
Have 2010, 34s, 4.88, auto, on Ours- Happy JK
Old Jul 26, 2013 | 09:20 AM
kh202's Avatar
I'm running 35's on my 2012 with 3.21's and a manual. I get between 14 and 17 mpg. Around town won't be so bad, the highway is what will kill you for power.
Old Jul 26, 2013 | 09:30 AM
MudBather's Avatar
Vet Army
For 35s you will need a small lift, (I recommend a 3") or flat fenders (You can cut your stocks). Since you are running stock 3.21s, I would recommend a re-gear at some point (maybe 4.10s). I am running stock 3.73s with 35s and manual transmission (this is about the minimum setup I would use). BTW, you will need wheel spacers or aftermarket rims with the correct offset/ BS to accommodate the 35s.
