balance beads?
Old Jul 30, 2013 | 11:37 PM
170-3tree's Avatar
Default balance beads?
I know that this topic has been best to death, but I have an interesting question.
the other day I broke open a tie at my shop to repair a flat and it had some debris in it, trash/ paper from whoever assembled it, the debris actually ate into the liner of the tire making me tell the customer that I wouldn't put it back on the wheel. it had actually eaten through some of the belting all the way around on the tread side internally.
can someone get a couple pictures of a set of tires using balance beads after some extended use? I'm torn on what would be found, being round would prevent such trauma, but being heavier than the debris I found my exaggerate the damage. keep in mind this was an suv tire with ~7500 miles on it with this stuff in there.
thanks for any help, I just want to know before I track the beads down for me and a customer that wants to put 40s on his blazer.
Gerald
Old Jul 31, 2013 | 06:28 AM
snakeyes76's Avatar
I ran dynabeads for around 6000 miles before going back to sticky weights. Beads didn't work well for me. But there were no signs of any wear in the tires when I removed them. Couldnt ever tell I ran with them. No pics, sorry.
Old Jul 31, 2013 | 06:52 AM
ronin2120's Avatar
Vet Army
I can't tell you what the inside of mine look like but I'm closing in on 30,000 miles and haven't developed any issues.
Old Jul 31, 2013 | 08:45 AM
goober0000001's Avatar
Next time I bust my beadlocks open on rotation I will take a closer look I haven't seen any signs of wear. I've been running them for almost 20, 000
Old Jul 31, 2013 | 10:42 AM
170-3tree's Avatar
Kinda what I figured guys. I just wanted to be sure before I put some in this guy's $650/tire setup.
Old Jul 31, 2013 | 11:21 AM
BKGM Jeepers's Avatar
I've run larger tires (37's or larger) for the past 12 years (JKU and TJs). I've nevered had trouble using traditional weights with my wheels, including running beadlocks.
I never thought that the beads could cause any problems to the wheel or tire.
