Superchips TrailDash OnBoard Module Kit and 3870 Flashpaq 10% off Sale 1998-2011 Jeep
Superchips Flashpaq Tuner, Jeep JK Wrangler
Increase your vehicle's horsepower from the palm of your hand. These Superchips flashpaq tuners will optimize both engine and transmission calibration throughout the entire power band. They are effective from part throttle through wide-open throttle.The FlashPaq combines Superchips' performance programming experience with cutting edge tuning and acquisition technology. Superchip engineers have been decoding and researching the ins and outs, or should we say 1's and 0's. of late model vehicles to design an easy-to-use tuner that offers what you expect from a tuner. The Flashpaq delivers the same Superchips' dyno proven performance calibrations you expect, but also much more.There are more tuning variables than ever, so you can add custom touches to your vehicle's performance. Also, the Flash Paq offers the ability to monitor engine and transmission parameters! This information will help you tune the most performance and economy out of your vehicle! Another great feature of the new FlashPaq is its ability to be updated via the internet! You'll never have to send the unit in to be updated - simply connect a USB cable through your PD and go to Superchips.com for any updates or tuning tips available for your vehicle.
Features include:
Number one engine and model Coverage in the industry
Greater increases in torque, horsepower and drivability
Works with most Cold air intake and cat-back exhaust Kits
Faster 1/4 mile & 0-60 times
Calibrate speedometer, odometer & shift points for tire and gear ratios
Monitor and record driving & vehicle performance with data logging
Adjustable shift points, firmness, speed and engine rev limiter
Real time vehicle sensor display
Check ignition timing and fluid temperatures.
*Superchips has not released the 2012-2013 updates yet
Traildash
Superchips TrailDash Module, Jeep JK Wrangler
Your off-roading and Jeep experience is incomplete without the Superchips TrailDash. The TrailDash is the most advanced Jeep tuner on the market today. The TrailDash was designed by hardcore Jeep enthusiasts and features Superchips' proven street and trail tunes which have been tested in multiple altitudes and climates including the legendary trails at MOAB.
Monitor Features
- 4.3" color touch Screen Transmission performance (Shift point adjustment)*
- Inclinometer gauges
- Customizable digital gauges (Reads numerous PIDs)
- Maintenance Manager (schedule and track maintenance)
- Mileage mentor (track and save fuel)
- Performance tests
- Reads and clears trouble codes
- Expandability (includes the ability to add aftermarket, accessories and sensors via the Superchips EAS
- Monitor includes video input and can run backup or other camera accessories
Program Levels*
- 91-Performance
- 87-Performance
- Heavy Load Towing
- Crawl
- Fuel Economy
- Factory Stock
PIDS
- Battery Voltage
- Battery temperature
- Corrected Speed
- Engine Coolant temperature
- intake Air Temperature
- Engine RPM
- Fuel Level
- gear Ratio
- Run Time
- Trip Odometer
- Trans Temp
Pitch and Roll Screen Pids and Options
- MPH-C
- Run Time
- Gear
- ETC
- Battery Temperature
- Fuel Level
- Battery Voltage
- IAT Temperature
- Trip Odometer
Off Road Features Screen 2 PIDs and Adjustable Options
- Crawl Tune for low speed off-roading
- Tire size, axle & transfer case gear calibrations
- TPMS threshold adjust
- TPMS off-road feature
- Real time idle up for threshold accessories
Custom Options
- Speed Limiter Adjustments
- Maintenance manager
- Mileage Coach
Data Logging
- Log and store up to 10 unique logs at a time
- Log hours of data
- View and graph logs on your PC using the new MyStyle software
- View all parameters or pick which ones you want to view
Screen 2 PIDs and Adjustable Options < /strong>
- Engine Idle
- Timing
2007-2010 Rubicon Specific Features
- Digital touchscreen front and rear axle lock
- Digital touchscreen sway bar lamp on/off
- Daytime running lights adjustability options
- 4WD-HI axle lock with auto-disengage safety features
Diagnostics < /strong>
- Trouble Codes
- Performance testing
- Records
* NOTE: Features vary be year, make, model and engine. Search by vehicle in question to find out the details. All Superchips tuning products for gasoline-fuled vehicles are either covered under CARB Executive Order number or are in a pending
Superchips TrailDash Module Dash Pod, 2007-2010 Jeep JK Wrangler with 3.8L
Superchips TrailDash Module Dash Pod, 1998-2006 Jeep TJ Wrangler with 4.0L
Get your Superchips tuner at a great price and free shipping at JEEP Parts | JEEP Accessories | BASELINE 4X4 YJ TJ JK Wrangler CJ
Free Shipping on all Superchips Tuners and Accessories!
Contact Baseline 4x4 Outfitters at 866-554-5946 for more information.
