2013 Rubicon dana 44 rear axle
Old Aug 1, 2013 | 08:19 PM
Jeepingolfer's Avatar
Default 2013 Rubicon dana 44 rear axle
Ok guys, has anyone else heard of or had a problem with the diff center section spinning the axle tubes? Mine apparently broke loose (crappy welds?) and allowed the pinion to point straight at the bottom of the tub, destroying the rear driveshaft cv joint and pinion yoke in the process. Just wondering what kind of fight I'm gonna have with Jeep on this, it's obviously a defect in the housing. I've had 4 jeeps all with 35" tires (as does this one) but never seen this happen not even to anyone else...
Old Aug 1, 2013 | 08:30 PM
larythebaker394's Avatar
Former Member
I have never heard of this issue. Do you have any pics that you could post?
Old Aug 1, 2013 | 08:32 PM
shag7265's Avatar
This happened to a guy in our jeep group. Sadly warranty did not cover it. He fought with jeep for 4 months. I hope you have better luck.
Old Aug 1, 2013 | 09:58 PM
Will grab some pics tomorrow before I take it to service, I can't see how warranty wouldn't cover it, the Jeep only has 7000 miles on it and is only 4 months old...
Old Aug 1, 2013 | 10:08 PM
Earth Siege's Avatar
I did that to my 78 trans am.
Had to get a metal plate and then wrapped a chain around the pinion and then weld the chain to the metal plate. Then place a floor jack on the metal plate under each tube (required 2 jacks) and jack the axle tubes up while the bottom of the jacks pushed against the metal plate which pulled the pinion back down. Once the pinion is where u want it, run a weld around both tubes. Problem solved. In fact, stronger than before.
Pinion yokes are available if u ask for them, alot of people have to remove them for u joint upgrade driveshafts.
Driveshafts are cheap if u get a stock pulloff unit
Old Aug 1, 2013 | 10:49 PM
nthinuf's Avatar
Lift and 35's is all some (many?) dealerships would need to tell you to go pound sand. Hopefully you will be able to get it pushed through, but be prepared to escalate if you get one of 'those' service managers.
This was starting to happen to mine, but it was caught early enough. My shop has seen a few, and noticed the bad welds while they were tearing down for a locker install.
Old Aug 2, 2013 | 12:23 AM
rtguy1's Avatar
i have a perfect condition pinion yoke if yah need it. free but you pay shipping from cali. it'll fit into one of the smaller flat rate boxes im sure. pm me if you end up needing it
Old Sep 15, 2013 | 07:27 PM
sicktwistedfreak's Avatar
Default what happened?
What happened with your axle issue? Wondering because my my 12JKU did the same thing this weekend, was planning on taking to dealer tomarrow.
