diff cleaning question
Old Aug 2, 2013 | 03:24 PM
stagedtrip's Avatar
Default diff cleaning question
I'm taking my front axle to work tomorrow to run it through the solvent tank. (I destroyed my front diff) is there anything else I need to do to aide in the cleaning? Obviously want to get all the chunks and shavings out, will some gas or diesel help soften it up overnight or should I just go solvent and maybe wd40 airhose it out and time to dry? Any input is appreciated
Sent from my NSA listening device
Old Aug 2, 2013 | 04:04 PM
karls's Avatar
Brakeleen works well for cleaning things up, but if you've got the axle in a solvent tank then you really shouldn't need to use gas/ diesel/ or brakeleen.
It would be a good time to do some anti-rust work on the outside of it while the axle is out.
Sent from my Droid4 and Jkfreaks.com
Old Aug 2, 2013 | 04:18 PM
stagedtrip's Avatar
Sweet thats what I was thinkin. And yeah while I've got both axles off I plan on busting rust, intense cleaning, and a full maintenance sweep
Old Aug 2, 2013 | 05:00 PM
Offroad_Elements's Avatar
Former Vendor
x2 on the brake cleaner. Stock up on a few cans! Will clean that out like a charm- good luck
