taking the grill off
Old Feb 8, 2008 | 06:01 AM
kntr's Avatar
Default taking the grill off
Im going to take the grill off. Is it going to be possible with the bumper on?
Old Feb 8, 2008 | 06:07 AM
hiteck's Avatar
It's hard to tell form that pic, but I was able to take my off with my shrockworks installed.
How high up does that bumper come up the grill?
There's 6 (I think) of those crappy push screws along the top, and several snap in clips along the bottom.
Old Feb 8, 2008 | 06:27 AM
wayoflife's Avatar
JK-Forum Founder
Hmmm, with the bumper as high up as it is, you might be able to but not without scratching up the bottom of it.... then again, that looks real tight and I would almost doubt it.
Old Feb 8, 2008 | 06:56 AM
dociain's Avatar
Default Removing Grill
I took the grill off with no difficulty.I have a Bestop rockcrawler bumper,Warn 9.5 and Grill protector rail fitted.Remove the silly top plastic screw in rivet and the grill is only clipped in at the bottom.
Best of luck.
Old May 25, 2008 | 12:40 AM
kalani's Avatar
kntr, i know you removed your grill to line-x it, was i possible to get it off with the ARB bar?
Old May 25, 2008 | 04:15 AM
pkdailey4's Avatar
You need about 2'' at the bottom
Old May 25, 2008 | 06:12 AM
Dustoff '68's Avatar
hard to tell.................
Old May 25, 2008 | 07:46 AM
kntr's Avatar
I removed the grill without removing the bumper. It was a little tight but it came off. It was much easier to get it back on.
