25-35 more HP?
Old Aug 4, 2013 | 02:06 PM
Saber6's Avatar
Default 25-35 more HP?
I'm running a 6" lift lift with 5.13 gears, dynomax exhaust and 37" wild peaks... Also put in the Ripp SC and feel I'm almost there. What can I do to pick up another 25-35 HP? Headers? Cam?
Let me know what you think and thanks in advance!!!
Old Aug 4, 2013 | 02:09 PM
Rebelyell22's Avatar
see if you can get a more aggressive tune for the Ripp?
Old Aug 4, 2013 | 02:15 PM
Ruby Tuesday's Avatar
LS/Hemi swap.
Old Aug 4, 2013 | 03:32 PM
Billbikes's Avatar
Tow vehicle, lol. I seriously doubt you'll get that much MORE, without going V8 or diesel.
Old Aug 4, 2013 | 03:42 PM
roscoj's Avatar
X2 for the hotter tune. Though it will likely not come close to those #'s. also will become less reliable.
Old Aug 4, 2013 | 05:09 PM
tcdawg's Avatar
Ripp long tube headers
Old Aug 4, 2013 | 05:23 PM
wytmike's Avatar
I would agree. Made a noticeable difference when I installed them. Still looking for more. The high altitude pulley also.
Done both and haven't looked back.
Mike
Old Aug 4, 2013 | 05:41 PM
Saber6's Avatar
I'm thinking the Ripp headers too... If they can offer an incremental ~20hp then I'm good to go.
I spend a lot of time in the Sierra's and the climbing with a full load (all three kiddos plus wife and gear) can be a little trying.
FTR the Ripp SC is really sweet and smooth!
Has anyone put the headers on after installing the SC? Also, any sound difference?
Thx
Old Aug 4, 2013 | 06:07 PM
zstairlessone's Avatar
So headers perform the job by using exhaust pulses to lower cylinder pressure below what a normal exhaust does. The SC greatly reduces the benefit by its nature (positive pressure in the intake forces the charge into the cylinders. You will still get a power increase, just not nearly as much as with a normally aspirated engine. Have you done the usual? Timing, hotter spark so you can open up the gap, cooler air in, CAT back, camshaft upgrade etc...
Old Aug 5, 2013 | 09:20 AM
wytmike's Avatar
Yes I put the headers on after the supercharger. Made a noticeable difference. It is quite a bit louder with the headers. RIPP recommends the hushpower on there website and I would agree. Way to loud and harsh without it.
If you are doing a lot of driving at Tahoe, I would highly recommend the smaller pulley they offer. At 7000' it makes a difference.
Mike
