Help me pick my protection
Old Aug 5, 2013 | 12:19 PM
Gkarshens's Avatar
Default Help me pick my protection
I am going to be going to the Jeep Jamboree in Hot Springs, AR in Oct. I want to add more protection under my 2012 JKU. I am looking at the Evo off road Pro Tek skid plates and the Riddler diff covers. I am hoping to add both, but may only be able to afford one or the other. So if you had to choose which would you add?
Old Aug 5, 2013 | 03:07 PM
Cozmik's Avatar
I'm assuming the Evo ProTek is coverage for the trans/motor/oil pan? That's the route I went with the Rock Hard skid plate. I was less worried about my duffs and more concerned with the motor and trans. Diff protection is still on the list however.
Old Aug 5, 2013 | 03:11 PM
Ghost63's Avatar
Don't forget the EVAP Canister--Jeep should have painted a target on that thing, it's just asking to be hit
Old Aug 5, 2013 | 03:39 PM
Billbikes's Avatar
The 12's at least come with an attempt at a plate/cage for the EVAP. Thus there are very few aftermarket options. I have a MORE Evap skid.
Old Aug 5, 2013 | 04:10 PM
Gkarshens's Avatar
Yes the Evo skid covers the engine/trans/oil pan. I guess a damaged or leaky diff is not as big an issue as a messed up tranny or oil pan. I will look into the evap canister protection too. Looks like Poison Spyder makes one for about $90. Thanks for the replies.
Old Aug 5, 2013 | 05:07 PM
idiotec's Avatar
I went with the rockhard skid that protects the oil pan and transmission. Very solid and provides one smooth surface which I like.
For the EVAP, I haven't done it yet but look into the relocation kits.
Old Aug 5, 2013 | 05:13 PM
Gkarshens's Avatar
I just got under there and looked and mine does have a skid over the evap canister. While I was looking I figured that the most exposed link under the jeep right now is the steering stabilizer. I think I will go with the Rancho Kit as it has a relocation kit and new stabilizer all in one. I already have a Rancho lift that I am super happy with too. I just need to have someone dump a couple grand in my lap so I can get everything I need protected! Any takers???
Old Aug 5, 2013 | 05:59 PM
idiotec's Avatar
Yeah, like I said I haven't done it yet, but that stock EVAP skid looks like a tin can to me.
Old Aug 6, 2013 | 05:24 AM
Nwapache's Avatar
That's, actually, a tough question.... Skids are a lot sexier to have, but, IMHO....you're more likely to crack a diff cover than the oil pan. Those stamped tin diff covers from the factory are garbage, and draining diff fluid will ruin your day real fast.
I would, and have, spend the money on a quality pair of covers and lube lockers before belly skids.
Old Aug 6, 2013 | 06:59 AM
Gkarshens's Avatar
I agree. After laying under the jeep trying to imagine rolling over rocks the steering stabilizer and front diff look really exposed. I just ordered the Poison Spyder diff covers.
