Jeep JK Wrangler Tube Doors and Half Doors at Baseline 4x4 Outfitters - Free Shipping
Old Aug 13, 2013 | 04:51 AM
Baseline 4x4 Outfitters's Avatar
Former Vendor
Default Jeep JK Wrangler Tube Doors and Half Doors at Baseline 4x4 Outfitters - Free Shipping
Like the “doors off” feel but also want the added convenience and utility of having doors on the trail? Rugged Ridge Tube Doors are constructed from durable 1.5” mandrel bent steel tube that is E-Coated primered and then textured powder coated for a long lasting finish. Tube doors help increase visibility when climbing obstacles and trail riding. The Tube Doors interchange easily with the factory steel doors and require no body modification for installation. They are light weight and small enough to be stored easily in back of the vehicle when not in use.
Features and Benefits
· Thicker than most other tube doors with durable 1.5” diameter steel tubing construction providing added strength and great looks.
· E-coat and textured powder coat for corrosion resistance.
· Tube doors provide added convenience and utility for improved visibility on the trails.
· Design to work with your original mirr or or for added convenience permanently install a pair of Rugged Ridge replacement mirrors.
· Adjustable nylon door strap allows you to control and adjust how far the door opens.
· Tube doors are easy to install and remove and are small enough to be stored in the vehicle.
· Optional cargo storage kit available that can be configured to use in a variety of ways.
· Durable and lockable paddle handle.
· Sold as a front pair and also a rear pair is available for 4 door JK.
· Attaches to factory hinge and door latch locations, easy no-drill install.
11509.10 - Rugged Ridge Front Tube Door Kit, 07-11 Jeep JK Wrangler
11509.11 - Rugged Ridge Rear Tube Door Kit, 07-11 Jeep JK Wrangler
13247.01 - Rugged Ridge Molle Pal Tube Door Cargo Cover with Storage Bags, Black, Fits Rugged Ridge and Most Other Tube Door Designs, Jeep Wrangler TJ 1997-2006, JK 2007-2011
11509.01 - Rugged Ridge Half Door Front Pair, Jeep Wrangler JK 2007-2011
11509.02 - Rugged Ridge Half Door Rear Pair, Jeep Wrangler JK 2007-2011
The new Rugged Ridge® Half Door option every JK owner has been looking for! Our new Half Doors provide open air excitement and freedom along with added functionality and convenience. High quality features and performance along with attractive pricing makes them a winning combination. The strong and durable design is built to last and features a paintable impact resistant thick plastic outer shell that is virtually dent proof. The outer and inner shells attach to enclose an internal powder coated tubular steel door frame that provides maximum structure and support. The do it yourself Half Doors interchange quickly with the factory steel doors and NO drilling or modifications are required. Each door features lockable door handles, an internal storage pouch, weather proof door seals, OE style cast steel hinges, and mirror mounts.
