Would installing sarah springs on a sport give any lift?
Old Aug 13, 2013 | 07:27 PM
Hughbear's Avatar
Default Would installing sarah springs on a sport give any lift?
I'll get the spring numbers whenever I get a chance to look at them.
Old Aug 13, 2013 | 07:41 PM
karls's Avatar
Typically there isn't too much benefit to the 4drs, but if your springs are sagging and wore out then yeah- totally worth it.
Sent from my DROID4 using Tapatalk 4
Old Aug 13, 2013 | 09:29 PM
JKBANDIT55's Avatar
If your going springs from a 4 door rubi with hardtop and tow package onto a 2 door then yes. But on a 4 door not really.
Old Aug 13, 2013 | 11:06 PM
RedRockJeeper's Avatar
Actually I never understood that, unless you get them dirt cheap, you can purchase a 2" set of springs and not have to worry about issues of lifting. A set of brand new after market springs are very reasonable.
Old Aug 14, 2013 | 03:11 AM
08rubie's Avatar
But then u loose ur warrenty
Sent from my Obama phone using JK-Forum
Old Aug 14, 2013 | 04:48 AM
karls's Avatar
The 4dr hardtop rubi thing isn't always true- I had a friend who purchased a set of coils from the original owner of a 4dr rubi ordered with all of the options and he didn't end up with 19/60's. I bought coils from some Joe schmoe and got 18/60's.
As far as why, price, etc........I got 4 coils (18/60), 6 shocks, 4 LCA's, a pitman arm, and a steering stabilizer for $50. Sold the shocks for $20 and CA's for $35. Even without selling the stuff- you won't find a 2" lift for $50.
Old Aug 14, 2013 | 04:53 AM
kh202's Avatar
You won't lose your warranty just because you install a lift. Dealer replaced my seatbelt retractors that were jammed because of this stupid little stunt. All depends on the dealer!
As for springs, compare the springs numbers. Generally, every one number you go up= 1/4" of lift. Ie fronts 14 to 16= 1/2"
Old Aug 14, 2013 | 07:39 AM
08rubie's Avatar
Originally Posted by kh202
You won't lose your warranty just because you install a lift. Dealer replaced my seatbelt retractors that were jammed because of this stupid little stunt. All depends on the dealer! <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=488148"/> As for springs, compare the springs numbers. Generally, every one number you go up= 1/4" of lift. Ie fronts 14 to 16= 1/2"
My dealer voids warentys for any little thing
Old Aug 14, 2013 | 07:43 AM
kh202's Avatar
Well then I'd take your business elsewhere and tell em to pound sand
Old Aug 14, 2013 | 07:59 AM
08rubie's Avatar
Yeah that's what I'm thinking
