Toxic Brakes - 3000 PSI Braided Stainless Steel Brake Lines, Teflon Core- Made in USA
Old Aug 28, 2013 | 01:28 PM
Baseline 4x4 Outfitters's Avatar
Former Vendor
Default Toxic Brakes - 3000 PSI Braided Stainless Steel Brake Lines, Teflon Core- Made in USA
Experience the benefits of Toxic Brakes Stainless Steel Braided Brake Lines.
Toxic Brakes Brake Lines are proudly made in the USA in accordance with all Federal and DOT regulations. It is our commitment to you to provide a top quality product designed to meet the extreme performance requirements that you demand from your vehicle. Each hose is specifically designed and tested to fit your application.
Top 10 Benefits of Toxic Brakes Stainless Steel Performance Brake Lines are:
1. Replacing OE rubber hoses with Toxic Brakes hoses eliminates pedal sponginess under having braking due to less volumetric expansion for improved braking and firmer pedal .
2. Teflon inner core makes these brake lines compatible with all DOT approved brake fluids including DOT 5 Silicone.
3. Suitable for all applications including extreme racing.
4. Each brake line is designed to meet DOT Standard FMVSS-106 and SAE J1401.
5. Every hose is pressure tested to 3000 psi.
6. Each brake line kit is designed to physically fit the application it is designed for without any additional fittings or adapters.
7. All fittings are zinc plated for corrosion resistance.
8. All Toxic Brakes Stainless Steel Brake Lines come with a 90 Day Warranty.
9. Every kit is designed, manufactured and assembled in the USA!
10. Chicks dig them!
2007-2014 Jeep JK Wrangler
1997-2006 Jeep TJ Wrangler and Unlimited
1987-1995 Jeep YJ Wrangler
1976-1986 Jeep CJ
1984-2001 Jeep XJ Cherokee
1993-1998 Jeep ZJ Grand Cherokee
Need more options? Longer Brake Lines? Custom Brake Lines?
Contact our Brake Divsion at Toxic@ToxicBrakes.com or toll free at 1-866-554-5946
Old Sep 2, 2013 | 08:36 AM
Former Vendor
Get your Custom Stainless Brake Lines today for your Jeep at Toxic Brakes
Old Sep 5, 2013 | 06:32 PM
Former Vendor
Get your Toxic Jeep Brake Lines today!
Old Sep 9, 2013 | 09:46 AM
Former Vendor
Get your Heavy Duty Stainless Brake Hoses today from Toxic Brakes
Old Sep 11, 2013 | 07:20 AM
Former Vendor
Custom Jeep JK Wrangler Braided Brake Hoses that are made in the USA!
Old Sep 13, 2013 | 12:38 PM
Former Vendor
Toxic Brakes Custom Brake Lines come with 1 piece fittings to provide the most durable fittings on the market
Old Sep 18, 2013 | 06:13 AM
Former Vendor
Free shipping on Custom Length Braided Brake Hoses for Lifted Jeeps
Old Sep 19, 2013 | 12:27 PM
Former Vendor
Custom Jeep Brake Kits for Lifted Jeeps are available from Toxic Brakes
Old Sep 22, 2013 | 06:10 AM
Former Vendor
Toxic Brakes are DOT approved brake hoses
Old Sep 24, 2013 | 03:21 PM
Former Vendor
Get your Braided Brake Hose Kits today
