Crusie Control won't engage in 5th Gear after fitting 2.5'' Lift & 35's!!!!........??
Old Sep 5, 2013 | 02:02 AM
UK_Jeeper's Avatar
Default Crusie Control won't engage in 5th Gear after fitting 2.5'' Lift & 35's!!!!........??
Hi All,
Just fitted a RC 2.5'' BB and 315/75/16 Cooper STT's to my JKU last weekend. Cruise control was working fine until then. Its a 6 speed stick shift. Now for some reason cruise control will only engage in 4th and 6th gear! But not in 5th for some unknown reason.
@ 30 mph in 4th its doing 1650ish rpm Cruise engages as it should
@ 40 mph in 5th it doing 1750ish rpm Cruise won't engage (even at higher speeds in 5th!0
@ 50 mph in 6th its doing 1800 rpm and Cruise engages without a problem and works at higher speeds....
After fitting the lift the steering did not need to be re-centred. it has a Dana 44 on the rear (with a Trac-loc diff i think as when ive been off roading it had the characteristics of an LSD) but not sure about the gearing. have tried to get a build sheet but with no success!
I don't know if anyone else has suffered with a similar problem??.... Any help would be much appreciated!
Cheers
Brad
Old Sep 5, 2013 | 07:37 AM
bombout800's Avatar
Try disconnecting the battery cables for 20 mins or so.
The only time mine wouldn't work is when the steering wheel was off center a hair.
Old Sep 5, 2013 | 08:01 AM
Jersey_Devil's Avatar
X2 mine did it at low speeds.... Battery disconnect worked
Old Sep 5, 2013 | 10:08 AM
UK_Jeeper's Avatar
Cheers guys will give it a try tomorrow!.....
Old Sep 5, 2013 | 10:10 AM
kh202's Avatar
My cruise occasionally doesn't work.. Solution??? Honk the horn, push cruise button, works instantly
