Bent Tie Rod
Old Sep 8, 2013 | 11:41 AM
Krawlersaur's Avatar
Default Bent Tie Rod
Morning all. Anyone know by chance what, if any, aftermarket tie rod will fit in a Pro Comp series 98 steel wheel? 15" with 3.75" BS. Was out wheeling this weekend, and I bent mine pretty good. Threw a tow strap on it, attached a winch to the strap, and slowly pulled it 'straight'. Not perfect, by not as bad as it was. No wobble or shimmies on the 45min 65mph ride home. Heres an after pic, after we kinda straightened it out.
http://imageshack.com/scaled/large/856/fb8w.jpg
Sorry, file was too large to load, and idk how to shrink it.
Old Sep 8, 2013 | 12:53 PM
Jersey_Devil's Avatar
Mines been bent since March!
Old Sep 9, 2013 | 05:16 AM
Bump for a possible answer!
Old Sep 9, 2013 | 05:55 AM
wheezer's Avatar
I've got a Synergy chromoly tie rod and I'm running 15's. It's a tight squeeze, but it fits. So far it's held up to all the abuse I put it through. Plus, both ends are identical and replaceable!
$325.00 at Northridge 4X4 & free shipping. Give them a call. They shoul be able to tell you if it'll fit with your wheels & back spacing.
Old Sep 9, 2013 | 08:52 AM
Mark Doiron's Avatar
I can tell you that the Currie barely fits in a 16 inch wheel--I have to make sure they don't put any balance weights on the inner edge of the wheel because they will be scraped off. So I'd say a 15 is a no go.
Old Sep 9, 2013 | 09:02 AM
wheezer's Avatar
Here's a pic of my Synergy bar. It's a tight fit but no rubbing at all.
Old Sep 9, 2013 | 09:07 AM
Thanks man, that might be the route I go.
Old Sep 9, 2013 | 09:48 AM
wheezer's Avatar
No problem! Thank you for serving our country!!!
Old Sep 9, 2013 | 10:06 AM
Maertz's Avatar
Id go chromoly imo. This is 1.5 od by. 25 wall and on my first trip it bent back to the dif and up on the passenger side... I will be using 2" od by 3/8 wall next
