Cherokee D30 Carrier 3.73 and Spider Gears in 2012 JK D30?
Modified JK TechTech related bulletin board forum regarding subjects such as suspension, tires & wheels, steering, bumpers, skid plates, drive train, cages, on-board air and other useful modifications that will help improve the performance and protection of your Jeep JK Wrangler (Rubicon, Sahara, Unlimited and X) on the trail.
I believe the carrier dimensions are the same, i.e. standard D30, as well as the spider gears (assuming they are 27 spline). The ring and pinon are not. Pinion shaft is completely different.
Thanks. Ya I don't need the ring and pinion just the carrier and spider gears. I blew my spider gears on the trail this weekend. Hopefully this will fit. And then I'm gonna buy some 4.88 gears front and rear to install because my ring gear had some chipped teeth as well.
