33's on 15'' wheels
Old Sep 13, 2013 | 06:38 AM
Killfoot1775's Avatar
Default 33's on 15'' wheels
Will I have to re-gear? I have a 2007 4 door with the 3.8. Thinking about some 33s with 15''wheels If I have to what is the recommended gearing?
Old Sep 13, 2013 | 06:48 AM
afpilot82's Avatar
JK-Forum Ambassador
33s will be fine on your stock gearing. Spending $1000-1500 for a gear install doesn't seem worth it to me unless you step up to 35s. What gears do you have now?
Old Sep 13, 2013 | 06:52 AM
kh202's Avatar
Yup X2. Some people make it out to be worse than it actually is
Old Sep 13, 2013 | 07:10 AM
lkinmond's Avatar
Yeah you'll be fine... just make sure your 15's fit the JK - some do, some don't.
Old Sep 13, 2013 | 07:15 AM
Lol to be honest with you I do not know, it's stock. Whatever stock is.
Old Sep 13, 2013 | 07:18 AM
Really? That's why I'm going to the 15s bc my stock don't work all that great with my Synergy upgrade( tie rod assembly ) I have rubbing in the driver side wheels and don't want to go the spacer route. Thx
Old Sep 13, 2013 | 07:23 AM
jeep_pride's Avatar
Let me jump in, I'm playing on switching mine tires to 35/12.5/17.
Should I be planing on switching gears?
I drive a 2013 sport 2 door
Really that's why I'm trying to upgrade. I upgraded my tie rod assembly to Synergy and my driver side wheels are getting chewed up. I don't want to go the spacer route.
Old Sep 13, 2013 | 07:28 AM
jeep_pride's Avatar
Meant to say planning not playing...damn auto spell check
Old Sep 13, 2013 | 07:29 AM
kh202's Avatar
Depends if you have auto or manual, and what gears you have. I have a 2012 Sport with 3.21's, manual and 35's and it ain't too bad, just don't expect to use 6th gear. 5th gear is a perfect rpm range on highway. I still tow my bass boat with it too That being said, slow crawling offroad will have you stalling a bit more often. But a 4:1 transfercase solved that problem for me
