Off Road & Ultra Cool - Aluminum Radiators for your JK
Old Sep 13, 2013 | 07:37 AM
Autoplicity's Avatar
Forum Sponsor
Default Off Road & Ultra Cool - Aluminum Radiators for your JK
Whether you are sitting in traffic in your stock Jeep or ripping through the trail in your supercharged JK, a reliable and effective cooling system is a necessity for reducing engine component wear and for increasing engine longevity. The Mishimoto Jeep JK all-aluminum radiator is precision engineered for direct bolt-in fitment that requires no modification to your vehicle. This radiator provides significant increases in efficiency, thanks to its 1.5” thick core and 160% increase in volume over the factory radiator. The Mishimoto Jeep JK radiator is constructed from high-quality, aircraft-grade aluminum with TIG-welded end tanks and a 100% brazed aluminum core. Our radiators are designed and built to handle the rigors of off-roading, severe weather environments, and competitive driving. This radiator is designed to improve heat dissipation significantly, making this an ideal upgrade for a stock or modified 3.8L. The Mishimoto Jeep JK Performance Aluminum Radiator includes a 1.3 bar radiator cap and the Mishimoto lifetime warranty.
OVERALL SIZE
29.40” x 21.65” x 6.89”
CORE SIZE
22.00” x 20.30”
ROWS
2
INLET
1.5”
OUTLET
1.5”
CORE THICKNESS
1.57” (40mm)
TANK WALL THICKNESS
.08” (2mm)
DRAIN PLUG THREAD SIZE
M12 x 1.5mm
PURCHASE INCLUDES
Mishimoto Radiator
Magnetic Drain Plug
Additional Mounting Hardware
Aluminum Mounting Tabs
Mounting Clips
Limited Lifetime Warranty
FITS
07-11 Jeep Wrangler
07-11 Jeep Wrangler Unlimited
ENGINE CODES
EGH (3.8L)
CHASSIS CODES
JK
Old Sep 16, 2013 | 09:14 AM
Forum Sponsor
Happy Monday! Everyone have a good weekend?
Old Sep 17, 2013 | 07:32 AM
Forum Sponsor
Tuesday bump!
Old Sep 20, 2013 | 09:19 AM
Forum Sponsor
Happy Friday!
Old Sep 23, 2013 | 08:23 AM
Forum Sponsor
Happy Monday yall!
Old Sep 24, 2013 | 06:35 AM
Forum Sponsor
Back up top!
Old Sep 24, 2013 | 08:23 AM
Tuto's Avatar
Went to your website and could not find the radiator.
Does the radiator comes for Automatic JKs ? Does it has a built in transmission cooler ?
Old Sep 25, 2013 | 08:48 AM
Forum Sponsor
Unfortunately, our site host has not pushed the most recent mishimoto update. Ill pm you more info
Old Oct 1, 2013 | 12:30 PM
Forum Sponsor
Back up top!
Old Oct 3, 2013 | 12:52 PM
Forum Sponsor
Back up top!
