Stock spring lift question
Old Sep 17, 2013 | 01:53 PM
warpeg's Avatar
Default Stock spring lift question
My '08 JKU X has 15/16 springs in the front and 58 springs in the rear. It has a soft top and no heavy add-on equipment. What kind of front lift can I expect if I go to 18's? What kind of rear lift can I expect with 59's?
Old Sep 17, 2013 | 02:00 PM
blue project's Avatar
Minimal at best. If your wantjng to see aift you can notice you need to go with a leveling kits. The weight difference for springs is maybe hundreds of pounds, not going to net you anything worth while.
Old Sep 17, 2013 | 02:03 PM
jadmt's Avatar
JK-Forum Ambassador
going from stock 58's to 60's got me about 3/8-1/2" at best. rode the same.
Old Sep 17, 2013 | 02:07 PM
nthinuf's Avatar
70-some pages worth of stock coil info. Enjoy...
https://www.jk-forum.com/forums/stoc...uestion-85825/
Old Sep 17, 2013 | 02:09 PM
tribulation138's Avatar
going from 15 front to 19 front u may get a inch. it will be slightly stiffer.
Old Sep 17, 2013 | 04:42 PM
RND's Avatar
RND
If they are thee original springs and shocks, go ahead and do the swap, REGARDLESS of what amount the ....!
