P0123 P0113 codes ... any idea? can the dealership tell if the computer was flashed?
Old Sep 18, 2013 | 07:59 PM
pauldana's Avatar
Default P0123 P0113 codes ... any idea? can the dealership tell if the computer was flashed?
i am popping these codes, P0113 intake air temperature sensor 1 circuit high input. And P0123 Throttle/pedal position sensor a circuit high input. any idea?
Also, can the dealership tell if the computer was flashed? if so does it give dates? i flashed it back to stock, but i do not know if it keeps dates and codes of past flashes?? if it does, how to erase them?
how to reset the "change oil" indicator?
2010 jeep JK wrangler automatic
thx!!!!
Old Sep 18, 2013 | 08:12 PM
ronjenx's Avatar
Was any maintenance done just prior to the codes popping up?
I don't think anyone has seen any evidence the dealer can tell if you have used a programmer once it's reset to original.
To reset the oil change warning...
Turn the key to ignition ON, but don't start the engine.
Press the gas pedal to the floor 3 time within 10 seconds.
Turn the key to OFF.
The warning should not come on when you next start the engine.
Old Sep 18, 2013 | 08:20 PM
pauldana's Avatar
supercharger to stock work,,,
Old Sep 18, 2013 | 08:23 PM
ronjenx's Avatar
Sounds like the connectors for the two items may not be seated, or one of the pins in each is dirty or bent.
