Help fabbing up trailer light harness braket
So I installed a 4 Pinn trailer light wiring harness. I can't find a bracket locally for the connector part. Anyone have any pics of brackets or ides. I have a aftermarket rear smittybuilt bumper. I thought it would be cool to cut a whole out of the bummer to mount the plug in, but didn't want to go hacking without some possible examples.
Thanks in advanced Doug.
Make your own template. Take a piece of cardboard and lay your plug on it and trace it out. cut out the area outlined and there is your template. You can use either one. If you are going to use the inner piece check for fitment and then trim if needed.
R/
Will
R/
Will
