Tatton Aftermarket DS and OEM links
Old Sep 29, 2013 | 02:35 PM
aaronstephen's Avatar
Default Tatton Aftermarket DS and OEM links
I just ordered a Tatton aftermarket driveshaft but don't have adjustable control arms. I am only at 2.5" of lift so I have net felt the need to upgrade my links yet. Do you think ill experience any driveline vibes?
Sent from my iPhone
Old Sep 29, 2013 | 02:37 PM
Biggy's Avatar
With that amount of lift I doubt you would have vibes.
Old Sep 29, 2013 | 03:25 PM
so what caster degree do vibes usually start in at?
Old Sep 29, 2013 | 03:31 PM
nthinuf's Avatar
Caster
Swaybar ?
No, with that size lift and stock arms, you should not have a vibe issue. That usually happens with taller lifts when people raise the caster (which lowers the pinion) to get rid of the flighty steering.
Old Sep 29, 2013 | 03:53 PM
ok, thanks
Old Sep 29, 2013 | 04:17 PM
yafoz77's Avatar
I have a 3.5 lift in front and 2.5 in rear with a Tatton shaft.. Stock control arms, works fine for me. The shaft has taken a lot of abuse and has held up no problem.
Old Sep 29, 2013 | 04:34 PM
Great to hear. Thanks
Sent from my iPhone
