front shock bolts - how tight?
Old Sep 29, 2013 | 05:26 PM
janders82's Avatar
Default front shock bolts - how tight?
throwing some new shocks on and wondering how tight to tighten the the upper shock bolt for the fronts (i don't currently have a torque wrench).
i cranked them down to where the bushings is pretty much the same diameter as the washers. tight enough?
Old Sep 29, 2013 | 05:31 PM
justin22's Avatar
It will be Ok until you drive to the store and pick up a torque wrench
Sent from my SGH-I337M using Tapatalk 2
Old Sep 29, 2013 | 05:49 PM
janders82's Avatar
Originally Posted by justin22
It will be Ok until you drive to the store and pick up a torque wrench Sent from my SGH-I337M using Tapatalk 2
yep. def need to pick one up. BUT i don't have one so any real answers would be much appreciated. thanks guys!
Old Sep 29, 2013 | 05:50 PM
DKehler's Avatar
20 ft lbs. Project-JK.com - Jeep JK Wrangler Resource » Jeep JK Wrangler Torque Settings
Old Sep 29, 2013 | 05:54 PM
janders82's Avatar
ok, i know the spec is 20ft/lbs...anything wrong with tightening till the bushing is about the same diameter as the washer?
how tight is too tight
Old Sep 29, 2013 | 05:55 PM
Maertz's Avatar
hah fan of both forums huh?
Old Sep 29, 2013 | 05:56 PM
janders82's Avatar
haha. gotta make sure i get all bases covered.,.
Old Sep 29, 2013 | 05:57 PM
Maertz's Avatar
i hear ya im just glad i threw out a dead nuts guess!
Old Sep 29, 2013 | 06:07 PM
river2c's Avatar
The rubber bushing should just begin to bulge out when the top nut is tight enough. They don't have to be tight at all but you don't want them to work their way off either. Bottom bolts are 56 ft/lbs I believe.
Old Sep 29, 2013 | 06:12 PM
kaptkrappy's Avatar
The bushings should crush to the point where the nut bottoms out on the shoulder on the stud to achieve the desired torque.
I'm looking for a pic, but front shock studs have a stop at the bottom of the threaded portion, that's what stops the nut and lets it tighten up/ stop turning.
