Deep vibration
Old Sep 30, 2013 | 03:31 PM
Hammerstien's Avatar
Default Deep vibration
I am getting a deep bass like vibration coming from the rear in between 55 and 60 miles an hour. I just did a five tire rotation and had all five wheels balanced. Two weeks ago I did do rotors and pads in the rear but I don't think that has anything to do with it. I have a 2010 JK you with a foreign a half inch lift 37 inch MTR's and I still have my stock rear driveshaft. The front was upgraded two years ago. Any help would be greatly appreciated I'm thinking it's the driveshaft.
Old Sep 30, 2013 | 03:55 PM
nthinuf's Avatar
Remove it and go for a drive in 4hi ?
oleskool's Avatar
Does the vibration stop when you let off the gas?
Old Sep 30, 2013 | 04:03 PM
It doesn't matter if I'm on the gas or not. That's what's throwing me off
I wish I had the time but there's no way I'm gonna be able to pull the DS before the weekend and test drive it. Going wheeling ha
Old Sep 30, 2013 | 04:05 PM
Smitty12JKU's Avatar
Doubt it is the driveshaft. That would be a higher frequency. More like a buzz usually with vibration. Do you hear a clanking sound when let off the gas? Does it resemble wind buffeting? Kind of like when you roll a window down to just the right spot? Try changing the AC settings like vent or recirc and different window positions. If the sound changes with different air settings, inspect the vent flaps on the tailgate. If not I would inspect the wheel bearings and axle shafts.
Old Sep 30, 2013 | 04:14 PM
No clanking. It's sounds like the car next to me is blasting base but I guess it could kinda be like a wind buffeting. Ill definitely check that and thanks for the new idea.
Rear bearings are barely a year old. I just upgraded last fall but I'll pull em when I get a chance and take a look.
I'm not overly concerned cause I don't actually "feel" a vibration it's more like a hear it but it's such a deep sound that I feel it a bit like base. Ha sorry best descript I can do
Old Sep 30, 2013 | 09:26 PM
MarwanJeeper's Avatar
check the angel of drive shift.
Old Oct 1, 2013 | 01:44 AM
kjeeper10's Avatar
Vet Army
What is your caster/pinion angle up front with the double carden ?
Old Oct 1, 2013 | 01:55 AM
Nothing has changed with either DS so it can't be that
Old Oct 6, 2013 | 03:44 PM
Did you ever figure out what it was?
