15 inch rims on jk
Old Sep 30, 2013 | 05:45 PM
Loveit's Avatar
Default 15 inch rims on jk
Can I put 15x10 rims on a jk or is 16 the smallest i can put
Old Sep 30, 2013 | 05:49 PM
kh202's Avatar
Depends which wheels. 3.75" back spacing or less is key. Here's mine. Discount tire has a list guaranteed to fit. Steel wheels like cragar are hit and miss. I'd recommend 15x8 or 9 as well vs the 10" unless you're goin with 13.5" wide tires. It'll def hold a better bead when aired down vs the 10" Click image for larger version
Old Sep 30, 2013 | 05:52 PM
BuckLisa's Avatar
You limit your ability to get a beefier tie rod since there will be interference.
Old Sep 30, 2013 | 05:57 PM
karls's Avatar
I've got 15x10's without issues and the options are really not as limited since the wheels sit out fairly far. As far as the bead goes......I've come down to 16psi (which isn't crazy low, but it is aired down) without losing a bead with 10.5" wide tires.
You'll find many people who will discourage the setup but for what I want and need- it works great and there's no need to shy away from it.
Sent from my DROID4 using Tapatalk 4
ID:	501642   Click image for larger version
Old Sep 30, 2013 | 06:03 PM
kh202's Avatar
Originally Posted by karls
I've got 15x10's without issues and the options are really not as limited since the wheels sit out fairly far. As far as the bead goes......I've come down to 16psi (which isn't crazy low, but it is aired down) without losing a bead with 10.5" wide tires. You'll find many people who will discourage the setup but for what I want and need- it works great and there's no need to shy away from it. Sent from my DROID4 using Tapatalk 4
Nothing wrong with the setup for sure and it will work, just not ideal depending on wheeling plans/ needs. I rarely run above 14 psi on any trails, usually 10-13. Just throwing my 2 cents to the OP
Old Sep 30, 2013 | 06:19 PM
karls's Avatar
My point exactly, we're on the same page- "airing down" is different for everyone, so 10 wides wouldn't be as grand for 10-13psi. I know I won't have to go that low so I opted for wider wheels. The 8 or 9 would be great for that pressure and the typical 12.5" tire.
Old Sep 30, 2013 | 06:22 PM
Smashboogie 4x4's Avatar
Former Vendor
As long as you have 3.75" Wheel backspacing the RK and Synergy Tie Rods will work with 15" wheels. Depending on which wheel you actually have you can have 4" back spacing and still clear the Synergy Tie Rod.
https://www.facebook.com/photo.php?f...type=3&theater
The link above shows the Synergy Tie Rod with a 15x8 Cragar Soft 8 with 4" of backspacing.
Old Sep 30, 2013 | 06:24 PM
kh202's Avatar
Originally Posted by Smashboogie 4x4
As long as you have 3.75" Wheel backspacing the RK and Synergy Tie Rods will work with 15" wheels. Depending on which wheel you actually have you can have 4" back spacing and still clear the Synergy Tie Rod. https://www.facebook.com/photo.php?f...type=3&theater The link above shows the Synergy Tie Rod with a 15x8 Cragar Soft 8 with 4" of backspacing.
Awesome, I know a friend of mine did that. I was waiting to hear back from him on which brand. Good to know, thanks
Old Sep 30, 2013 | 06:34 PM
BuckLisa's Avatar
Good t know thanks!
Old Oct 1, 2013 | 01:51 AM
kjeeper10's Avatar
Vet Army
If you recall my Synergy tie rod did not work with my 15" Black rock vipers.
