Steering stabilizer bolt question
Old Oct 2, 2013 | 02:15 PM
nik81818's Avatar
Default Steering stabilizer bolt question
This bolt keeps coming loose any body have a solution to it
Sent from my DROID RAZR using Tapatalk 4
ID:	502119   Click image for larger version
Old Oct 2, 2013 | 02:22 PM
karls's Avatar
Lock-tite should be your first move but if that doesn't work then throw a small tack weld on the end of it.
The bigger question is- "why is it coming loose"?
Sent from my DROID4 using Tapatalk 4
Old Oct 2, 2013 | 02:32 PM
MMXJKU's Avatar
Are you tightening it enough?
Old Oct 2, 2013 | 02:33 PM
nik81818's Avatar
Yes using an impact to tighten and used thread lock also. Only been doing city driving since tightened
Old Oct 2, 2013 | 02:59 PM
Jersey_Devil's Avatar
Duck tape maybe? Lol but seriously just use some thread locker and u should be fine.
Old Oct 2, 2013 | 03:02 PM
nik81818's Avatar
Thread lock didn't with. I used the red and it still came loose
Old Oct 2, 2013 | 03:08 PM
DJ1's Avatar
DJ1
Former Member
try slapping on a lock washer either by itself or on top of the washer that I think/looks like is already on there...
Old Oct 2, 2013 | 03:35 PM
Gman*2007's Avatar
You might try installing a new nylon insert locking nut. It's hard to tell from the picture but the nut looks to be a crimped locking nut.
Old Oct 2, 2013 | 06:35 PM
familytime's Avatar
JK Forum Regional Rep
If you used red loctite and it came loose again,you did something wrong.Without heat this stuff is pretty hard to loosen after it dries. Try nylock nut,crush nut or even safety wire it
Old Oct 2, 2013 | 10:35 PM
nik81818's Avatar
So this time I used the red lock tight and let it sit for a few hours I'll c how it holds up. I also changed the bolt and the nuts as well
