Tuner that rids a 3.6L lack of 0-1500 power
I can't take it any longer. Can anyone with personal experience recommend a tuner that rids the lack of power until 1,500 rpm when this thing takes off like a raped ape? I see in Ads that they increase throttle responce, but I want my power right off idle like every other engine I've ever had. None of these say that so I'm asking here. Thanks
I've been running the Diablosport Trinity since they released support for the 2013's and the 93 octane tune is pretty stout I think. It pulls everywhere in the RPM range if you want it to. I have been pleased with it. To my knowledge this is the only tuner for the 3.6 besides the Hypertech which is a piggyback harness offering up under 5hp gains which I decided to pass on.
Hope this helps
Hope this helps
The 3.6 does have more power, just not much below 1500 RPM's. When mine was new it was really bad. It didn't want to pull sixth with 32" tires, and 3.21 gears at anything below 65 MPH. Now that it is broken in, I think (14,000). I can put it in sixth on my way to work 45-55 MPH, and it will maintain speed. I don't have any passing power, but it will go up & down hills at those speeds. If I need to pass I just bring it around to Fourth, and press down on the loud pedal. That gets her above 2000 RPM's.
I really notice the lack of power down low after I drive my 98 XJ with a 4 liter. That old inline six was the best engine for a Jeep. It grunts right from the bottom, but the JK does jump up & scream better.
