Rear Wheel Bearing Out??
Old Oct 7, 2013 | 01:16 PM
meep97's Avatar
Default Rear Wheel Bearing Out??
When driving down the road I hear a squeaking noise and kind of a thud noise. I can feel the back end bounce up and down a little too at slower speeds. And when making turns the noises get louder and it clicks. My guess is a rear wheel bearing. Anyone have any information as to if I could be correct?
Old Oct 7, 2013 | 01:38 PM
meep97's Avatar
Also, the noise seems to go away when breaking.
Old Oct 7, 2013 | 02:48 PM
kjeeper10's Avatar
Vet Army
Why don't you get the rear up on stands ?
Could be a few different things. As far as the rear .. Bent flange, bearing, something with the brakes.
Do you wheel the jeep?
Old Oct 7, 2013 | 03:03 PM
TheDirtman's Avatar
I would check the calipers to make sure they are tight.
Old Oct 7, 2013 | 03:12 PM
meep97's Avatar
Everything is fine. It's somewhere in the shaft, either it's bent or the bearing is out. But! I can't get the damn shaft out on the passenger side!! Is there a C clip in the housing or something???
Old Oct 7, 2013 | 03:17 PM
ronjenx's Avatar
No c-clip. It's just the four nuts on the retainer plate.
Old Oct 7, 2013 | 03:25 PM
meep97's Avatar
Yep, got them loose. Damn thing wont budge!
Old Oct 7, 2013 | 04:57 PM
kaptkrappy's Avatar
It's slide hammer time.
I got one from Northern Tool cheap.
Not a JK axle, but you get the idea.
Old Oct 7, 2013 | 06:14 PM
meep97's Avatar
Finally got the shaft out. The bearing was in perfect condition. With a little more research and a few more answers from a couple other forums I decided it was a bent flange on the passenger side axle shaft. So I just bit the bullet on some Nitro Gear chromo axle shafts for both sides from Northridge4x4. Hopefully they get here before the weekend so I can install them!
