bumpstops
Old Oct 8, 2013 | 04:56 PM
jlfuksa's Avatar
Default bumpstops
Just a curious question, maybe a dumb one! Have stock bump stops 3" lift with bilsteins 35's . Will smaller bumpstops allow more flex?? Can I cut them?
Old Oct 8, 2013 | 04:59 PM
Offroad_Elements's Avatar
Former Vendor
If the shocks are made for the 3" lift they'll get damaged at full up travel by bottoming out, you may also have some fender rubbing issues. I would definitely extend the bump stops sooner than later.
Old Oct 8, 2013 | 05:03 PM
nthinuf's Avatar
From your profile pic, you are running without fenders? Yes, less bumpstop will increase the up-travel, until the point where the shocks over-compress and you destroy them. Run the numbers and see what you come up with, but you are probably better off leaving them as is.
Old Oct 8, 2013 | 05:22 PM
jlfuksa's Avatar
Ok thanks, ya I just gonna leave them, dont need to be buyin new shocks! Guess I will invest in some arms
