Which steer stabilizer to get?
Old Oct 13, 2013 | 04:31 AM
mrbigwrench's Avatar
Default Which steer stabilizer to get?
Doing some homework on quality steering stabilizers. I've been told Fox is probably the best. Quadratec lists 1 for $130 and the top of the line model for $355.
I have Ranchos all the way around my JK now, but my parts guy tells me they're still a cheap, Mexican made shock.
My question: is the midrange Fox shock better than the Rancho? Or is there another brand that's reasonably priced and superior to the Rancho? Any advice is appreciated, thanks!
Old Oct 13, 2013 | 04:34 AM
familytime's Avatar
JK Forum Regional Rep
Is something wrong with your stock one?
Old Oct 13, 2013 | 04:37 AM
Jersey_Devil's Avatar
Fox is definitely an awesome way to go! I want the Fox shocks with res. And the Fox 2.0 stabilizer is awesome!
Sent from my obama monitoring device
Old Oct 13, 2013 | 04:44 AM
I was having death wobble issues. All other components have been checked and hardware replaced, so the steer shock is the last piece of the puzzle.
Old Oct 13, 2013 | 04:51 AM
TJM12's Avatar
I have a rancho steering stabilizer and haven't noticed it to be inferior? In fact they are pretty decent quality shocks dollar for dollar.
Old Oct 13, 2013 | 04:57 AM
Philip *AZ*'s Avatar
If you still have DW there is something still wrong. I can drive my JK w/o a SS and it drives fine. The SS is only going to mask a more serious issue. The stock SS should be fine. I would have kept mine, but it was plain worn out. Personally I would double double check everything before you install a new SS. I currently have a Bilstein SS since I have Bilstein shock I wanted everything to match. The stock SS would do the same job though. My $.02
Old Oct 13, 2013 | 05:09 AM
I understand all the potential problems with DW and have checked things out, ball joints, bushings, etc. Our local Jeep repair specialist, Jeep Doctor, tells me a quality SS has solved 98% of DW issues that he knows of. So I want to upgrade without shocking the bank acct out of $400.
Old Oct 13, 2013 | 05:33 AM
TJJK's Avatar
i understand all the potential problems with dw and have checked things out, ball joints, bushings, etc. Our local jeep repair specialist, jeep doctor, tells me a quality ss has solved 98% of dw issues that he knows of. So i want to upgrade without shocking the bank acct out of $400.
old man emu
Old Oct 13, 2013 | 08:02 AM
Ryan0260's Avatar
You have something else going on. Stock stabilizer, or any stabilizer, is only going to mask the issue that is causing the DW.
Old Oct 13, 2013 | 09:45 AM
07tungsten's Avatar
I also have a Rancho SS and am pretty happy with it.
