Nitro Axle Shafts from Olympus Offroad
Old Oct 13, 2013 | 06:02 PM
TH3APPL3GUY's Avatar
Default Nitro Axle Shafts from Olympus Offroad
After an incident while off-road with some friends, my JK was making an AWFUL squeaking noise. I was able to track the issue down to a bent passenger side axle flange. I contacted Olympus Offroad and literally within minutes of sending an email I received a highly-detailed response that answered all of my questions, once again Olympus leads the way with their customer service. I decided to order a set of rear axle shafts. Three days later my axle shafts arrived at my door, ready to bolt on the jeep.
I found a writeup on removing the rear shafts on JK-Forum. In about 45 minutes I had both factory shafts out and the nitro shafts installed. The drivers side measures 30.79" and the passenger side measures 32.50".
After torquing all of the necessary hardware, I took the jeep for a quick spin.... NO MORE SQUEAK! I was happy that my squeak and my wallet was even happier, thanks to the great price from Olympus Offroad.
Old Oct 13, 2013 | 06:10 PM
JE8154's Avatar
how much did you pay?
Old Oct 13, 2013 | 06:15 PM
Check your PM box
Old Oct 13, 2013 | 06:18 PM
Double post
Old Oct 13, 2013 | 07:10 PM
TURTLECON's Avatar
You didn't have to press the bearings? It just bolts right up?
Old Oct 13, 2013 | 07:11 PM
The shafts came with the bearings pressed on and wheel studs installed.
Old Oct 13, 2013 | 07:41 PM
nthinuf's Avatar
Yep, the Nitros come pre-assembled. But they are quite a bit more expensive, and have a worse warranty, than others. You'd think they would have dropped the prices by now to compete.
Old Oct 13, 2013 | 07:45 PM
It is an option to have them pressed. They arent that much more expensive than the other brands.
Old Oct 14, 2013 | 05:03 AM
kjeeper10's Avatar
Vet Army
Tens are $425-$450 ready to bolt in. I've seen cheeper too.
Old Oct 14, 2013 | 06:34 AM
Maertz's Avatar
yup i got tens for $400 pressed on from northridge.
