trans oil temp??? anyone know what is norm and high?
The OBDII reads the sump temp (trans oil pan).
Normal operating temp is 180F.
I believe the TC won't lock until you're over 80F.
The Hot Oil warning reportedly triggers at 240F.
Personally, I think >200F is too hot.
The '07-'11s benefit from auxiliary coolers.
With a B&M cooler, my '08 rarely goes over 150F.
Is your gauge an OBDII reader? Or did you install a sensor somewhere?
OBDII reader.
I am heading for Moab this weekend, in the past I haven't had any troubles but I also never knew how hot it was getting. It will be nice to see the opperating temps while I am crawling around.
I emailed Ron@superchips asking if there was an oil pressure reading somewhere in the 3875 but at this time that is not an option. Sure would be nice though.
If I saw 275 in my trans, I'd be changing that fluid ASAP. Hell, if I saw 240 I'd do a partial change.
First time I saw 200 I put on a B&M cooler.
Just did a pan drop fluid and filter change at 60k. The improvement is remarkable (and I didn't even think it needed improvement before doing the change).
Putting a magnafine filter onto the cooler line and plan to do a partial change annually from here on out. I use a mighty-vac fluid extractor pump to draw the fluid out the dipstick tube.
