Custom Fab Jerry Can mount for 08 JK Sahara with Stock Bumper
Old Oct 15, 2013 | 11:09 AM
VicPerz's Avatar
Default Custom Fab Jerry Can mount for 08 JK Sahara with Stock Bumper
ID:	505263Click image for larger version
ID:	505264Click image for larger version
ID:	505265Click image for larger version
More to come
Old Oct 15, 2013 | 02:31 PM
Septu's Avatar
What a tease.
Old Oct 15, 2013 | 03:11 PM
PG-JKU's Avatar
We're dying here man - show us the goods MOUNTED for crying out loud!
Old Oct 16, 2013 | 04:14 AM
cgn152's Avatar
Here here!!!! Let's see it and where to send my money for one!
Old Oct 16, 2013 | 05:11 AM
familytime's Avatar
JK Forum Regional Rep
Old Oct 16, 2013 | 09:25 AM
VicPerz's Avatar
Originally Posted by familytime
Upon further research I determined that with the full weight of the Jerry Can being 45 lbs I have decided to tie this set up into the top tailgate hinge as to better secure the weight and prevent any flexing that could potentially snap the bolt heads loose. Once I get it mounted I will add more photos. This is a hand crafted prototype design so if it works as I believe it will and you are interested in having one for yourself, I will try to come up with a fair yet reasonable cost for purchase.
Vic
Old Oct 16, 2013 | 09:31 AM
PG-JKU's Avatar
Vic
That's kind of what I was thinking too, that a simply bottom mounted unit would not hold up, but was sure hoping to see some photos even to see where it was going to be mounted. So how will it work to tie into the stock bumper as well as the hinge? Will you still be able to open the tailgate?
I think it's a bit early to ask if people want one, when we haven't been able to see what you are cooking up! Come on, humour us with a pic, even just one that shows where you were planning on putting it with the first bracket.
Old Oct 16, 2013 | 11:31 AM
VicPerz's Avatar
Yes the tailgate will still open. It will be lmited to about 95% open before the can makes contact with the tail lights. I will be putting flush mout tail lights on my Jeeper which will resolve that issue. The mount is designed to sit 'in" each hinge where the hinges are bolted into the tail gate. The stock bolts will be replaced with grade 8 bolts. Here is a pic of the somewhat finished look without the piece being added today. The tire on there now is a stock 255 70/R18. This set up will not allow for a larger diameter. My whole goal is to keep my Jeeper looking as stock as possible. I only mentioned the "resale" based on a below inquiry. This may not even work although at this point my math only indicates that it will hold and hold well.
ID:	505509 Click image for larger version
Old Oct 16, 2013 | 09:08 PM
PG-JKU's Avatar
Awesome. I hope it works out for you. I've looked for similiar ideas - not really sold on the Rotopak type.
Sent from my GT-P3113 using Tapatalk now Free
Old Oct 17, 2013 | 02:04 AM
VicPerz's Avatar
Those things are aweful... hopefully ill have it mounted up tonight
