How often do you check tire pressure?
Old Nov 3, 2013 | 07:33 PM
JoeRaj's Avatar
Default How often do you check tire pressure?
Fellow Jeepers, how often do you all check for tire pressure and fill air if necessary? I have13 JKU with 315/70r17 Duratrac!s and was set to 30psi when I installed a month ago. Now my tpms warning came on indicating 24 psi on right rear and left front (rest are 25psi) after I parked outside all evening at 35F (it's Michigan). I know cold temp tend to drop the air pressure but just one day of parking outside? Or do you guys think I have a slow leak? Any insight and advice would be great. Thanks
Old Nov 3, 2013 | 07:37 PM
k0260's Avatar
Yes the temps do make the pressure fluctuate, I check my pressure once a month on avg.
Old Nov 3, 2013 | 08:09 PM
Jeek.OlllllllO's Avatar
My buddy checks his every week I do it once a month also but I don't drive my jeep to much!
-Jeek
Jeepin on a budget
Old Nov 3, 2013 | 08:16 PM
gunbo75's Avatar
Every two weeks or when the weather conditions and temperature changes. 75k on my toyo mt now.
Old Nov 3, 2013 | 08:17 PM
Bushmaster's Avatar
Don't panic. Just pump them up as required. If you have to do it all the time(once a week) and they drop 5 psi each time and it's not able to be blamed on the weather then get them checked.
As a side note:
Bigger tyres will show more difference in pressure because of the higher volume of air inside the tyre.
That's my 2 cents. I hope it helps a bit.
Old Nov 3, 2013 | 08:22 PM
Radioman's Avatar
Veteran: Navy
I too check the tires about once a month. Make sure you are using an accurate gauge and use the same gauge each time. Tires will lose about one pound per month but temperature changes will also cause a change in your tire pressure.
Old Nov 3, 2013 | 08:35 PM
JKBANDIT55's Avatar
I need to start checking them more often. Noticed my MPGs were staying around 10MPG when I normally am around 15 with my 37s. So I checked today and they were at 18
Have no idea how they got so low... But I havent checked since my last wheeling trip. about a month ago.
I would say try to check them every other month or so.
Old Nov 3, 2013 | 09:25 PM
courtsm3's Avatar
Tires will drop psi over night with cold temps. Just check them when weather starts to cool off
Old Nov 4, 2013 | 05:04 AM
JoeRaj's Avatar
Thanks all! Let me air it back today and check back in a couple of days.
Old Nov 4, 2013 | 06:55 PM
DadsCJ's Avatar
I would say I check the dash PSI about every week to make sure things are good.
