Rock krawler lift with fox shocks
I this weekend my brother and I installed the rock krawler x factor lift kit with the fox 2.0 shocks I was guided to these shocks over the bilstein by north ridge 4x4 I am every happy I went with the fox shocks, after a full weekend of installing the lift. When I finally got the jeep out to drive over the bumps and ruts in the roads of western mass i felt like the vehicle tracked, and responded to the bumps better than stock
the X factor took a lot longer to install than I expected lol, but well worth it
I run the 3.5" x factor, if you plan on wheeling it be sure to cycle it and add appropriate bump stops. If not your shocks will not last long. This lift is essentially endless with flex and the shocks wear quickly when used as bump stops and/or limiting down travel.
