OEM Rubicon rock rail or OEM side step hardware for 2012 or newer JK
Old Nov 5, 2013 | 07:10 AM
BILLARF's Avatar
Default OEM Rubicon rock rail or OEM side step hardware for 2012 or newer JK
For those that will need this info as I did this am .............
After speaking via telephone with 4 different part's guys this morning, I finally spoke with one older parts guy that was nice enough to drop what he was doing and take the time to investigate and report to me the exact bolt / nut sizes, etc.. He just happened to have a set of rubi rails with hardware that were just pulled off of a '14 JK. 8-)
Anyway, for the 2012 and newer JK's you need the following hardware when you install either OEM rubi rock rails of OEM side steps:
1) 8mm 1.25 pitch 30mm length Grade 9 hardened hex head bolts
(you need 4 of these for the 2dr) Also need washers/lock washers
2) 6mm x 1.0 pitch Nylock nuts
(you need 8 of these for the 2dr.) Also need washers
Note: With 2012 and newer JK's you do not use "U-nuts". They are not required.
Also, 30mm length as mentioned above is just a little less then 1.25 inches in length.
Old Nov 5, 2013 | 05:19 PM
BILLARF's Avatar
Follow-up post just to mention that I purchased the hardware mentioned in my original post and indeed the hardware sizes were found to be correct when i did a test fitting today. Just figured I would mention that I confirmed the info in my original post. I'm sure this info will be useful to others installing OEM rubi rails or OEM Side Rails on a 2012 and newer JK.
Old Mar 15, 2014 | 10:22 AM
reddenedbeard's Avatar
Thank you for posting this .. got some Rubi Rails today with no hardware.. Jeep told me that they don't just sell the hardware.. thanks again!
Old Mar 16, 2014 | 07:16 PM
Range_Time's Avatar
On a kind of related note i just got a set of these for my 4 door. I'll post some photos next weekend when i have them welded on.
Jeep DIY Side Step | Rocker Armor | Parts & Accessories | Off-Road Upgrade |
Old Jun 29, 2014 | 12:39 PM
Quantum_Doc's Avatar
Default Double Trouble
This post is great and may be able to help me. So I bought a 20120 Rubicon with the Rubi Rock Rails already on it. I picked up a set of OEM steps for a good price. I was considering trying to install the Steps with the Rails, to have a hetter look in the end. I have not lined up anything, and am just brain storming at this time. Any thoughts on the best way to do this?
Old Apr 9, 2015 | 07:23 AM
dokken08's Avatar
On my way to Lowes now with this info. Just bought a pair of take offs for 100$ of CL.
Thanks for posting.
Old Apr 9, 2015 | 12:10 PM
dokken08's Avatar
Got what I needed for 7 bucks and they went on in 30 minutes. Thanks!!
Old Nov 5, 2016 | 11:25 AM
Gumbyhoss's Avatar
Default Thank you
Got some rails off CL and of course they didn't have complete hardware (no bolts). I live a block from the Jeep dealership so I called about the hex bolts and after 20 minutes on hold decided to google other solutions. Your post was by far the most helpful and I just completed the install. So thanks, and cheers to you.
Old Apr 30, 2020 | 10:04 AM
Flyin4now's Avatar
Default 4 door
Do you think this hardware would be the same for a 2017 4 door?
Old Apr 30, 2020 | 11:26 AM
resharp001's Avatar
Loved
Community Favorite
With the 4dr you'll need 6 of those bolts, and 12 of the nuts....otherwise yes.
