Can you upgrade 4" tera flex to long arm
What I would like to know is can you upgrade tera flex like you can upgrade Rubicon express to long arm. I'm looking to purchase the Rubicon super flex 3.5" and upgrade it later to long arm if I find myself needing it later. Tera flex is cheaper and may purchase that lift if I can upgrade it also. Plus I like the 4" over 3.5"
With only 4" of lift you don't need long arms.. Plus your gonna loose ground clearance from the brackets, which hang down several inches.
'13 JKU Sahara - modified.
