2014 jkur too wimpy of battery for Warn winch?
Old Nov 8, 2013 | 09:06 AM
jadmt's Avatar
JK-Forum Ambassador
Default 2014 jkur too wimpy of battery for Warn winch?
So I ordered a new Warn VR10000 and I find out that it says I need at least a battery with 650CCA and lo and behold my stock battery says it is 600CCA is this going to cause issues?
Old Nov 8, 2013 | 09:44 AM
11rubiwannabe's Avatar
It will work fine, for intermittent pulls. I've got a aeon 10 on the stock battery...spend your money on a marine grade circuit breaker instead
Old Nov 8, 2013 | 10:48 AM
scubatech's Avatar
By holding the rpm around 2500 or so the alternator shpuld handle most of the load while winching. Maybe if you were winching an extended distance for a long time it might use some battery voltage.
Old Nov 8, 2013 | 10:58 AM
jadmt's Avatar
JK-Forum Ambassador
ok I do have a procal and it has a feature to raise rpms.
What size breaker is needed? I was hoping that Warn would have one included with the winch.
Old Nov 8, 2013 | 09:02 PM
thegoat's Avatar
I had 5 long pulls using the stock battery, the battery light kept coming on and I was revving the engine the whole way... A week later my stock battery was so dead it couldn't be jumped. The stock batteries don't like being drained heavily.
Old Nov 8, 2013 | 11:25 PM
Mark Doiron's Avatar
Here's an easy mod once the current Group 91 battery fails ...
http://project-jk.com/jeep-jk-write-...ep-jk-wrangler
Old Nov 8, 2013 | 11:50 PM
catahoula's Avatar
Thanks Mark!
Old Nov 9, 2013 | 12:46 AM
gunbo75's Avatar
I have a Ultima battery yellow top works great.
Old Nov 9, 2013 | 03:10 AM
Bushmaster's Avatar
X2 on the ultima yellow top. My stock battery died after 2-3 uses. I also thought I could get away with it with high revs and intermittent pulls but in the end a yellow top was the best option.
Old Nov 9, 2013 | 03:24 AM
Capndik's Avatar
Diehard Platinum!
