Truck lites (I'm Sorry)
Old Nov 13, 2013 | 03:51 AM
orangeagent27's Avatar
Default Truck lites (I'm Sorry)
Just a quick question about these lights. Keeping in mind, I know absolutely nothing about electrical. Do I need any special harnesses or wiring, other than the anti flicker harness, to run these lights in my 2014 JKU? Thanks for any and all help.
Old Nov 13, 2013 | 03:52 AM
jadmt's Avatar
JK-Forum Ambassador
I am running a set on my 2014 jkur and am not running the anti flicker harness and I have no flickering. I bought mine thru Northridge4x4 and they came with the harness needed to do a plug and play.
Old Nov 13, 2013 | 03:53 AM
Kojack's Avatar
I am running the anti flicker harness and it works great!
Old Nov 13, 2013 | 03:54 AM
Great. So the h4 to H13 adapter works on stock light assemblies? Sorry, again it know very little.
Old Nov 13, 2013 | 04:47 AM
jadmt's Avatar
JK-Forum Ambassador
yes. Some get flickering others don't. I have used the same Trucklites on two different wranglers a `13 and now a 14 and neither had a flicker problem. I think they are the best upgrade you can make to a jeep if you drive in the dark. I usually go to work in the dark and come home in the dark and they have been worth every penny.
Old Nov 13, 2013 | 05:18 AM
Awesome! Thank you sir.
Old Nov 13, 2013 | 10:38 AM
DJ1's Avatar
DJ1
Former Member
Nope....degreed Electrical Engineer also...use some dielectric grease though and make sure you order the Truck Lites for the JK. It'll come with the correct connectors...
Old Nov 13, 2013 | 11:02 AM
jadmt's Avatar
JK-Forum Ambassador
yes dielectric grease is wise. I have an industrial size tube and it gets used on everything electrical.
Old Nov 13, 2013 | 12:46 PM
Northridge4x4's Avatar
Sponsoring Vendor
Truck-Lite 7'' Round LED Headlamp, Complex Reflector Optics Design - pair 27270C
Here is the best deal right now and the "anti flicker" harness is not required to get
David
Old Nov 13, 2013 | 01:36 PM
karls's Avatar
Holy hell David.....that's quite the deal, certainly better than another price I was looking at for my TJ (Q price)
Sent from my DROID4 using Tapatalk
