2.5" Lift Question
Old Nov 14, 2013 | 07:01 PM
NizmoJK's Avatar
Default 2.5" Lift Question
I went to my local installer today to order a lift/tires. Can you do a 2.5" lift with only Springs and Shocks (receipt did not say Kit just coils) and the Jeep still ride safe?
Old Nov 14, 2013 | 07:11 PM
brutalvette's Avatar
You will need new sway bar links for the rear. The rear get moved to the front. My kit also included a bracket for the rear track bar.
Look up a kit online and it should list all included parts.
Old Nov 14, 2013 | 07:15 PM
Also what size tires are you going to run? You need to make sure you have the proper wheel backspacing or get a set of slavers.
Old Nov 14, 2013 | 07:18 PM
NizmoJK's Avatar
That's why Iwas concerned. The place knows what they are doing and has a lot of great reviews. I didn't even think to question it before I left. I just noticed it when I looked at the receipt it says Coil Springs, Shocks, Labor, Tires. Nothing about a kit or sway bar links.
Old Nov 14, 2013 | 07:19 PM
NizmoJK's Avatar
I have aftermarket wheels with the right backspacing (4.5) - going to be running 35's
It could just mean coil spring kit. What brand are you going with? How much was "the coil springs"?
Old Nov 14, 2013 | 07:25 PM
NizmoJK's Avatar
Metal Cloak $300 - Has to be just the coils for this price.
Old Nov 14, 2013 | 07:43 PM
Yeah I would double check with them for sure. You'll need bump stop extensions too.
http://www.Metalcloak.com/JK-Wrangle...ate-p/7116.htm
Here is a kit. The control arms are not really needed by everyone though.
Old Nov 14, 2013 | 07:53 PM
NizmoJK's Avatar
I saw the kit and thought that was what we were going to do but I think it is going to be - JK Wrangler, 2.5" Dual Rate Coil Set, 2-Door plus Billstein's... I sent them an email and will call tomorrow.
Old Nov 14, 2013 | 08:32 PM
nthinuf's Avatar
You might browse through the big MetalCloak thread and see if you can find the actual lift height you can expect from the coils, based on your current model/setup. It wouldn't be a bad idea to go ahead and price out all of the individual components in the full kit linked above, since more than likely you will end up there anyway.
