Failing t-case?? About to explode??
Old Nov 15, 2013 | 09:25 AM
superjk10's Avatar
Default Failing t-case?? About to explode??
Hey guys i have just added front and rear 1310 driveshaft from coast driveline in my 2010 JKU rubicon... Now i have this loud Grinding noise in 2wd only when i take the traction control off and get the tires to spin.. Took it to a buddys shop and the yoke at the t case came loose a bit. Even though I Thighten her up at 160lb... So we tighten her up again and she was fine.. But i still have this little Grinding noise when im in 2wd and the traction control is off and it is coming from the t case. Wont do it in 4hi or 4 low. Just talk to a tech at chrysler and he said i could be some bearings in the t case... Anyone else had that issue? Is it worth rebuilding? Or upgrading it would be ideal...? Money is not an issue but.. Im trying to get chrysler to pass it under warranty..
I did some research on the forum but seems like im having a different issue with my tcase than Anyone else...
Tanks in advance
Old Nov 15, 2013 | 10:16 AM
k0260's Avatar
What degree is your caster set to? If it's set too high, this will cause heavy stress and wear on you t-case
Sent from iPhone moderating JK-Forum.com
Old Nov 15, 2013 | 10:30 AM
superjk10's Avatar
Caster is at 4.5*... I dont have any vibrations.. Just grinding noises
Old Nov 17, 2013 | 11:24 AM
superjk10's Avatar
Anyone else had that issue??
